I know it seems like a silly question.....
Jeff Thornton
Topic author - Scurvy Dog
- Vessel Info: 1989 Carver 2757 Montego CDRH5049J889, 1974 Ericson E27, 1996 Avon - Sea Rider -SR6 (Rigid Hull Inflatable) and a Nordica 16.
- Has thanked: 5 times
- Been thanked: 2 times
Any help or photos would be appreciated.
Thank you!
Jeff
Re: I know it seems like a silly question.....
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
T-Merc 350 Mag MPI (300hp)
http://www.fisheriessupply.com/perko-garboard-drain-plug-0266-0363-0370
Some Silvertons use the same idea but with no handle, instead it's a plug with a square or hex configuration that requires an allen or square key.
If you can't find the T handle type, you can use a regular plug. If I recall, it's 3/4" NPT, some are 1" NPT.
Jeff Thornton
I just ordered one, so we will soon see.
Jeff Thornton
I got my T-handle, got upside down and found that the hole is a lot smaller than that!!
Looks like former owner must have lost the original drain plug, did not want to pay the $98 perko replacement price so inserted a reducer down to 3/8". Went to the ACE got a 3/8" brass plug from the plumbing isle and we have a dry boat. I don't like that the insert raised the drain out level by about 3/4" or so.
