Steering not working on the 3207
Been thanked: 491 times
Re: Steering not working on the 3207
Postby waybomb » May 8th, 2014, 5:15 pm
I suspect you have two issues.
There should not be an overflow. The system is a completely closed system. There must be some sort of leak. It won't get better. You need to find that leak.
In a hynautic system, the wheel should turn and turn, no stop; it will feedback a higher resistance to turning once the rudder is deadheaded and the relief valve opens. I suspect you have a bad or stuck relief valve on the starboard side. The relief valve is in the block mounted on the bottom of the reservoir.
Topic author
jwrape
Vessel Info: 79' Carver 28 Mariner Twin Pleasurecraft 302's (For Sale $12,300)
85' Carver 3207 Aft with Mercury 5.7L
Postby jwrape » May 9th, 2014, 7:47 am
waybomb wrote:I suspect you have two issues.
Good to know, I will check it out and see when I'm out on Monday :captain:
nolacarver
Vessel Info: 1979 33' carver
New Orleans, LA
Postby nolacarver » May 14th, 2014, 10:10 am
It worked out . Thanks!
Cuyose
Vessel Info: 1985 Carver Voyager 28
Postby Cuyose » May 30th, 2016, 5:58 pm
Awesome this is exactly what I had happen today, good to know a simple steering servicing should fix it.
