we'll see Thursday when I get back to it. Maybe I should go tomorrow...Welcome to Carver Yachts Owners Forum
vacuflush leak and smell in head unit
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: vacuflush leak and smell in head unit
we'll see Thursday when I get back to it. Maybe I should go tomorrow...-
- cpoint
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
- cpoint
Midnight Sun
- Vessel Info: 2007 Carver 41 CMY D6 370's
- Has thanked: 1 time
Midnight Sun wrote:Source of the post Can you do a visual on the tank by shining a flashlight through it to determine how full it is. Maybe just a bad sensor or gauge playing games with you?
There's been a lot of people fooled by that!
crquisto brings up a good point if you have two tanks connected together in that manner.
As I mentioned above cpoint, you need to ensure with 100% certainty that what your indicator is telling you is indeed what's in the tank. Don't go by any shadowing that you see from the outside of the tank as you may be looking at a scum line inside the tank but fluids may be no where near that level. Unscrew the sensor assembly and check the level inside. While you have that out, clean it, and test it by moving the floats to see if the indicator responds properly.
Do you have an overboard discharge system hooked up?
- cpoint
Viper wrote:Source of the postMidnight Sun wrote:Source of the post Can you do a visual on the tank by shining a flashlight through it to determine how full it is. Maybe just a bad sensor or gauge playing games with you?
Thanks wiper and midnight sun, I will check I am on way there now. I had shined a light, it looked like there was 1/3 tank full of water. But agreed, I will open the top and check as well. However I am sure there is water coming into it. I am going to check to see if there is Y adapter as crquisto mentioned. I am 100% sure it is not coming from the head as I had replaced the valve and made sure no water was coming through. So there has to be another source where water is coming in to tank. Also overboard discharge system is not hooked up I believe.
- cpoint
crquisto wrote:Source of the post These issues are really frustrating. This is a long shot, but my 2000 406 had an issue where my forward holding tank was leaking thru the overboard pumpout y-valve. That's the one next to the onboard overboard pump, behind my port engine. I rebuilt the y-valve and the problem was fixed. My forward holding tank sits higher than the aft tank, so Gravity was allowed to do its thing. If your configuration has the aft tank higher, this could be an issue. Good luck!
I just checked the tank today, yes the water level in water tank is down, the holding tank definitely has water in it, it is not false indicator. Can you tell more how I can see if I can locate y-valve? any chance there is a picture of it? I will look for it, but not too much under google for these types of things.
- cpoint
