Not sure if older Promariner Charger is charging
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
Thanks in advance
Re: Not sure if older Promariner Charger is charging
Whether it's your charger or not, do yourself a favour and upgrade to a 3 or 4 stage Smart charger. You'll be glad you did. A couple of members have upgraded recently, perhaps they will chime in and give some feedback on what they think of the newer units versus the older counterparts they replaced.
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
I installed a brand new Promariner Pronautic 50 amp 3 bank smart charger this spring. This replaced my Charles C-charger which was charging intermittently during the bulk charging phase.... easy install and it works like a charm. It was truly plug an play.
I bought it through Amazon in the US and they delivered it to S. Carolina shipping included. The admiral was visiting her sister and she carried it back over the border.... easy peasy... $395US no tax!!!!
Fraser
- denders
. I doubt it is a bad battery or cell ( the batteries are brand new and expensive ) - I will double check the connections next week , other than the usual corrosion - anything I should be looking for ?-
Check the other end of the cables also, such as negative at the engine block, terminals at the charger and terminals at battery switches if applicable. A poor connection at any point in the circuit will result in a failure.
- denders
- feeez
I have been running my Promariner 50a for almost 2 months now and my battery charging is vastly improved and the charger is virtually silent.
Fraser
