1987 carver electrical problem
Topic author
eanderson560
Vessel Info: 1987 Carver Mariner
Re: 1987 carver electrical problem
Postby eanderson560 » June 6th, 2016, 2:35 pm
Ok I know exactly where it is. Any idea of replacement cost?
Topic author
eanderson560
Postby eanderson560 » June 6th, 2016, 3:17 pm
Ok I know where that is. Any idea of replacement cost?
Has thanked: 64 times
Been thanked: 481 times
Postby waybomb » June 6th, 2016, 3:23 pm
I took down all the numbers and went to steiner electric and picked them up there.
I really don't remember how much they were but maybe 60 bucks each.
Get a card of numbers so you can wrap each wire with a number. Draw what you see.
Number the terminals.
Lotsa wires.
Take a number of pictures.
AND UNPLUG THE SHORE CABLES AND TURN OF THE GENSET.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » June 6th, 2016, 9:13 pm
waybomb wrote:Source of the post Check the relays.
Take the cover off. Be very careful. Line voltage in there.
Plug both cords in.
Have somebody start the genny. Watch the relays.
Do you know how to use a vom?
Check voltage to the two ac voltage mains.
At the relays, the two incoming cords go to them.
The genset goes to them. Yes, when on genset the two combine automatically.
One of the relays is not letting genset current through.
Or you have a bad connection at the non-air conditioning relay on the genset side.
Agreed
