Clint,
Unfortunately, we don't have any information as to where they would have connected it. All we can tell you is that we recommend the following places in this order of preference.
1. Hose Tee: In-Line between the heat exchanger and riser. (as close to the heat exchanger as possible).
2. Hose Tee: In-Line between the oil cooler and heat exchanger.
3. Hose Tee: In-Line between the water pump and the oil cooler.
4. Drain Plug: Hose barb in the heat exchanger.
5. Drain Plug: Hose barb in the oil cooler (only if oil cooler is on the pressure side of the water pump). The bore should be at least .200".
6. Drain Plug: Hose barb in the back of the water pump. Be sure the drain is on the pressure side of the pump.
Thank you for shopping with
Tides Marine
Need help with Tides StrongSeal hose routing
anothernewb
Topic author - Scurvy Dog
- Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212 - Location: Space Coast Florida
- Been thanked: 21 times
Re: Need help with Tides StrongSeal hose routing
anothernewb
Port side riser---------seal---------seal----------?starboard side?
Is the pressure off of the riser enough for the seal?
