Apleco 530 deep sounder
Wkuhilltopperfan
Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
Has thanked: 17 times
Been thanked: 18 times
Postby Wkuhilltopperfan » June 27th, 2016, 9:31 pm
My display has went bad on my Apelco 530 depth gauge and we are looking for either a replacement display or a compatible display to mate to the original transducer so I don't have to remove the boat from the water just to replace the transducer which is expensive as everybody knows. Any help on compatible displays or used 530's would be great. We don't use the plotter , only the depth gauge.
Thank you
1998 350 Mariner
Been thanked: 646 times
Re: Apleco 530 deep sounder
Postby g36 » June 28th, 2016, 5:22 am
i have some apelco stuff i used to use at home not sure at the moment which model if you would like i will check. let me know if you havent moved on to something else.
Wkuhilltopperfan
Postby Wkuhilltopperfan » June 28th, 2016, 6:08 pm
g36 wrote:Source of the post i have some apelco stuff i used to use at home not sure at the moment which model if you would like i will check. let me know if you havent moved on to something else.
I think the Apelco 560 is also compatible from what I hear. If you have a 530 or 560 ..... That would be awesomeness
1998 350 Mariner
Postby g36 » June 29th, 2016, 10:30 pm
Sorry what I have is 260
Wkuhilltopperfan
Postby Wkuhilltopperfan » June 30th, 2016, 3:14 pm
Thanks for checking, it's appreciated
1998 350 Mariner
Users browsing this forum: No registered users and 40 guests
