2003 360SS - Head fan won't stop running
camelot
Vessel Info: Carver 360 SS
Been thanked: 2 times
Postby camelot » June 28th, 2016, 12:27 pm
I know that most of the posts here are about things that won't work, my problem is my head exhaust fan won't STOP - I thought that maybe the wall switch was fried and was stuck in an ON position, so I took that apart and disconnected the wires, but it is still running - the only way to turn it off is to go to the breaker panel - any suggestions?
Past Commodore 2016
Wild River Yacht Club
St Croix River - Hudson WI
Re: 2003 360SS - Head fan won't stop running
Postby tomschauer » June 28th, 2016, 12:47 pm
sounds like the switch controlled a relay and the relay contacts are closed.
I have no idea if the relay is in the electrical panel or near the fan. Do you happen to have a wiring diagram for the boat?
camelot
Postby camelot » June 29th, 2016, 8:55 am
Hi Tom -
Yes - I have all the original paperwork for the boat, so I think I could try to track it down - I will do some digging for it this weekend and repost - thanks!
Past Commodore 2016
Irish Attitude
Vessel Info: 2003 Carver 360 Sport Sedan
8.1L CRUSADERS
Postby Irish Attitude » June 29th, 2016, 9:00 am
Our 360 Sedan Bridge has a second fan switch in galley behind the sink on left side -One fan with two intakes, galley & head?
Opps Right side.... I mean STARBOARD
camelot
Postby camelot » June 29th, 2016, 10:22 am
Irish -
Thanks for the insight - I will check that switch out - maybe that is the culprit - never knew there was a second switch!
Past Commodore 2016
CaptBob
Vessel Info: Shopping....
Been thanked: 33 times
Postby CaptBob » June 29th, 2016, 12:24 pm
Yup, our 360SS has another fan switch behind the sink, both galley and head switch run the same fan.
Capt Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... :captain2: )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
camelot
Postby camelot » June 30th, 2016, 3:56 pm
OK, when I was a young boater, I would be embarrassed that a solution was so simple - but now, I am thankful it was as simple as that!!! I have had the boat for 2.5 years and never knew there was a galley fan! Thanks for the easy fix guys! If every fix could be that simple!! :usa:
Past Commodore 2016
CaptBob
Postby CaptBob » June 30th, 2016, 7:01 pm
Much better than my current problem where my hold-n-treat purasan decided to go on full reversal and empty my fresh water tank through the purasan tablet dispenser and fill my holding tank with nicely chlorinated water. Could have been really really worse! :banghead:
Capt Bob!
Users browsing this forum: MrMojoRisin and 56 guests
