AC unit not giving cold air
Been thanked: 248 times
Re: AC unit not giving cold air
Postby mjk1040 » July 3rd, 2016, 2:32 pm
Time for the AC man to take a look at it.MIke
Been thanked: 490 times
Postby waybomb » July 3rd, 2016, 5:02 pm
Does it throw out hot air when in heating mode?
Makin Waves
Vessel Info: 2006 Carver 46MY
Been thanked: 8 times
Postby Makin Waves » July 3rd, 2016, 6:48 pm
We switched to heat mode for a few minutes, no change
Postby Viper » July 3rd, 2016, 10:03 pm
If she's clean, the compressor is definitely running, she's pumping water, and neither the heat or cold cycles work, it's likely you have a refrigeration related issue such as the compressor or refrigerant charge. If I recall, this boat is new to you, do you know if there is a service history on this unit? Can't tell you how many times I've run into the wrong refrigerant/oil used in a repair. That'll toast the compressor for sure.
Makin Waves
Postby Makin Waves » July 4th, 2016, 6:56 am
I have a feeling I will be replacing this unit
Users browsing this forum: Google Adsense [Bot] and 33 guests
