Oil pressure question
Topic author Italy
Bankerbiz87
Vessel Info: 1982 Carver Mariner twin 220 engines 28ft
Has thanked: 10 times
Postby Bankerbiz87 » July 28th, 2016, 7:38 am
One of our engines has a oil pressure of 80 running hot what maintenance would you recommend ???
Thank you
Has thanked: 64 times
Been thanked: 481 times
Re: Oil pressure question
Postby waybomb » July 28th, 2016, 12:13 pm
I'll bet it is not 80psi but a faulty gauge or sender indicatingh 80.
Your mechanic can remove the sender and screw in a mechanical pressure gauge to verify oil pressure.
If in fact it is at 80, you must have a stuck relief valve and need to get that fixed. I've seen oil filters blown off of engines when a valve gets stuck.
And then usually something caused it to get stuck, metal, and it came from somewhere.
