vacuflush leak and smell in head unit
Re: vacuflush leak and smell in head unit
Postby tomschauer » July 29th, 2016, 8:45 am
Your holding tank should be under the floor of the aft cabin between the bed and head entrance. Also your shower sump and aft bilge pump should be in the same area. Two removable panels under the carpet.
cpoint
Has thanked: 208 times
Been thanked: 32 times
Postby cpoint » July 29th, 2016, 9:46 am
tomschauer wrote:Source of the post Your holding tank should be under the floor of the aft cabin between the bed and head entrance. Also your shower sump and aft bilge pump should be in the same area. Two removable panels under the carpet.
I will check when I get to it this weekend, but aft cabin carpet seems to be one unit, unlike main cabin there are no visible panels on the floor in aft cabin.
Postby tomschauer » July 29th, 2016, 10:13 am
Mine is also one piece. Start at the rear under the nightstand and pull it towards the front of the boat.
Postby tomschauer » July 29th, 2016, 10:14 am
the access panels are under the carpet
cpoint
Postby cpoint » July 29th, 2016, 3:14 pm
tomschauer wrote:Source of the post the access panels are under the carpet
Thanks, will check it out.
cpoint
Postby cpoint » July 30th, 2016, 1:04 am
Yes they were there after all. There were 2 large panels and 2 small ones. And tank is there. Also found bilge was dirty. Put some cleaning agent, will go back clean up tomorrow.
