Cruising on one engine
- Washopay
- Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers - Location: Barrie, ON
- Has thanked: 23 times
- Been thanked: 5 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: Cruising on one engine
2022 Stingray 182 SC
- Has thanked: 64 times
- Been thanked: 481 times
No matter what, to move xx pounds at xx speed takes xx horsepower.
If at hull speed, I'm not sure how much you'll save. What happens to the transmission if powered by the wrong end and in neutral? Will the oil pump still move oil?
Do you have a flo-scan installed? If you don't, you should. You would be surprised how a few degrees in trim affect fuel usage. You may save way more by monitoring fuel flow constantly.
- Been thanked: 1180 times
Keep in mind this was on a stern drive boat with fuel injected 383's so there may be some differences in your application.
- Has thanked: 469 times
- Been thanked: 1765 times
- for those with dripless shaft logs that are plumbed in to one another, there is a possibility of the non-running engine ingesting water through this line as it is forced through by the running engine. For this reason, Merc. does not recommend plumbing the two logs together, or running on just one engine if they are.
- under the right conditions; exhaust system geometry, no exhaust shutters, transom exhaust flap, etc., the non running engine can ingest water in swells or due to a following swell resulting from slowing down. The exhaust pressure of a running engine helps minimize this possibility.
I'm not against running on one engine, but one needs to consider more than just fuel economy. If you're going to consider this type of boating, ensure that at least the above items don't pose a risk.
I still say fuel is the cheapest part of boating.
Even with the go fast.
For the most part, recreational propulsion systems are meant to be running when the vessel is underway unless there is a reason such as a failure. If you don't ensure the risks are addressed, fuel economy will be the least of your problems.
- Washopay
