Hour gauges
Re: Hour gauges
Postby tomschauer » August 5th, 2016, 12:39 pm
no offense.
Re: Hour gauges
Postby Viper » August 5th, 2016, 9:05 pm
tomschauer wrote:Source of the post Viper, you may be onto something with the running on one engine. With the other prop running backwards wouldn't that make the hour meter for that motor run backwards, creating a greater disparity between the hour meters?
See, that's what I like about this forum, you learn something new every day! ;-)
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Hour gauges
Postby AaHubb » August 6th, 2016, 9:42 am
Huh. Mine are within a few tenths of each other.
..Aaron
'99 404 CPMY
SeaDragon
Re: Hour gauges
Postby tomschauer » August 8th, 2016, 8:55 pm
my meters are VDO not Hobbs. about 3/10 difference @ 250 hrs.
Erikpmn
Vessel Info: 1995 Santego 380
Re: Hour gauges
Postby Erikpmn » August 8th, 2025, 9:30 am
Hi there! I know this is an old thread but thought I’d share a recent experience. We had a pretty big storm a couple weeks ago and the helm on my 380 Santego got drenched. The fuses for my ignition got wet. While the boat would still start and all seemed fine, it appears the waterlogged fuses allowed a complete circuit. Therefore, my hour meters were clicking along even with the ignition in the off position.
Barrett50
Vessel Info: 2006 Voyager Pilothouse 57
Been thanked: 4 times
Re: Hour gauges
Postby Barrett50 » August 8th, 2025, 12:48 pm
Re: Hour gauges
Postby km1125 » August 8th, 2025, 4:40 pm
Not the fuses that would be an issue, but your ignition switches.
Re: Hour gauges
Postby bud37 » August 8th, 2025, 10:17 pm
Erikpmn wrote:Source of the post Hi there! I know this is an old thread but thought I’d share a recent experience. We had a pretty big storm a couple weeks ago and the helm on my 380 Santego got drenched. The fuses for my ignition got wet. While the boat would still start and all seemed fine, it appears the waterlogged fuses allowed a complete circuit. Therefore, my hour meters were clicking along even with the ignition in the off position.
I wonder if it is possible on your boat to shut down ( isolate ) the bridge power when you leave it. We always left all the boat circuits off except for the fridge.
ck36
Vessel Info: 2002 Carver 450 Voyager, TAMD74P
Has thanked: 17 times
Re: Hour gauges
Postby ck36 » August 20th, 2025, 11:04 am
My hour gauges which are a small LCD display above the digital RPM gauge are almost unreadable at both helms as the LCDs are failing. Interestingly though, when I plugged in the YDES gateway I just installed to get data out of the EDC there was a discrepancy in the hour meeting readings. On the stbd engine I was getting a reading of about 1900 hrs through the EDC. The gauge at the helm was showing 2700 hrs which is about the same as the port engine and should be correct based on historical records. The EDC records hours of actual engine operation while the helm gauge records hours that the ignition key is turned on. On the port engine there is a discrepancy of about 30 hrs (over 23 years). So the only thing this could mean is that the EDC was changed out at that time although I have no records from the first 9 years of the boat's life.
RyDrew
Vessel Info: 2004 360 Mariner
Purchased on October 14, 2025
Been thanked: 2 times
Re: Hour gauges
Postby RyDrew » October 16th, 2025, 11:07 am
Looking forward to hear what people think about your question. I have a very similar issue with my 2004 360 Mariner. Dash meters shows both engines virtually identical (572 Port/574 Stbd) while the ecm showed a big difference (565 Port/178 Stbd). The engines are both original with serial numbers very close to each other,
