Air Conditioner odor
Good News
Topic author - Scurvy Dog
- Vessel Info: 1995 Carver Santego 380 with 454xl crusaders
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Air Conditioner odor
- Been thanked: 646 times
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
Good News
- mjk1040
- Been thanked: 246 times
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
g36 wrote:Source of the post I don't know what boat you have but I can tell you I had the exact same problem with my carver 405. The AC unit under the front berth was drawing air from the bilge which does smell from the holding tank etc so when it was on it pulled the stink in to the cabin. I eliminated this by taking out the unit building a box inside the space to isolate the hvac from the bilge reinstalled the ac unit used flex duct for air return from the grille and reused the original supply ducts. It operates more efficently than it was cause I'm not heating or cooling the bilge space anymore and the smell is also gone. If you have any open area to the bilge like this your ac will do this also. Can't understand whose bright idea at carver this was but it's fixed on my boat now. I would check around this may be your problem also.
I am having the same issue in my 1994 CPMY and saw how the A/C in the aft cabin is drawing bilge air. Do you have a photo of the work you did? I was thinking the same thing of isolating the A/C via a barrier to the bilge and duct the return air from the area where the filter is, under the berth. A couple of photos would be SO helpful!
- tonyiiiafl
Users browsing this forum: kdward11 and 21 guests
