After couple months of ownership got around to testing the horn, no sound. Assumed if I don't hear it others wont either. So not sure bad horn or electrical issue. How can I test the power or horn. I hope I do not have to take apart the horn switch, as there is no easy access to below it. Is there a way to test from horn side, maybe check to see if power is going to it at leads on the horn?Welcome to Carver Yachts Owners Forum
2000 Carver 356 horn issues
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
After couple months of ownership got around to testing the horn, no sound. Assumed if I don't hear it others wont either. So not sure bad horn or electrical issue. How can I test the power or horn. I hope I do not have to take apart the horn switch, as there is no easy access to below it. Is there a way to test from horn side, maybe check to see if power is going to it at leads on the horn?- Washopay
- Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers - Location: Barrie, ON
- Has thanked: 23 times
- Been thanked: 5 times
Re: 2000 Carver 356 horn issues
1: Check that the small air lines are connected and not full of spider poo. If so, disconnect and clear them out. Very easy.
2: If still no horn, tune it. There are screws on the back of the horns bell. Remove and gently remove the reed (thin copper disc). Clean and spray with WD40. Don't not bend! Re-install and start slowly tightening the screws while someone simultaneously tries to honk it. You will hear it starting to make a noise until suddenly it starts to sing. Then do the other.
3: If this doesn't work, i have no clue. A friend at my marina told me this, I tried it and it worked.
VERY satisfying when you hear the BWAAAAHHH!!! I can barely keep myself from playing with it.
Good luck.
After Taxes
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
MerCruiser MX 6.2
Lake Simcoe, Ontario
- Been thanked: 490 times
So sweet. Had them on our 4207.
Click on the "hear it" button.
http://www.kahlenberg.com/products/marine-signaling/yacht-horns/model-d-2-chimetone-air-horn
You can remove the 6 or 8 screws from the switch panel and tilt it front to check the switch, or you can voltage check at the horn if you have the same cheesy horn as me.
If it sat awhile as mine did, you may need to just clean the wasp nests out of it and spray some wd into the horns.
- cpoint
- cpoint
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- mjk1040
- Been thanked: 248 times
- cpoint
