1973 Monterey 2585 bringing her back to life
Re: new member with a 1973 Monterey 2585
Try doing a Google search for a manual.
- lrfickau
- Vessel Info: 1973 Monterey 2585 OMC 225hp single IO
"SEA STAR" - Location: Lake Geneva Wisconsin
- Been thanked: 5 times
The hull is in great shape but I do not know what I have with the engine (OMC 8cyl GM small block 180 hp) or drive. The first thing I will do is to get it to run. Now for drive there is no throttle/shifter on the console, it has been removed. I'm unfamiliar with stern-drives and I see no cable or would it be electric (if anybody has a OMC service manual they would like to donate It would be very helpful). By the way I live just a mile away from this wonderful lake, Geneva Lake in southeast Wisconsin. with a lot of old boats the summer home of Wrigley's and Maytag's back in the day. This is were this boat has spent its days with an occasional trip spent on Lake Michigan. I hope you will share with me and I make my way with her restoration.
Re: 1973 Monterey 2585 bringing her back to life
Sorry, no manual.
- lrfickau
- Been thanked: 490 times
- lrfickau
- lrfickau
Hope all goes well.
Drained the fuel.
Pulled the distributor.
Ran a preluber for many minutes.
Pulled the plugs.
Squirted trans fluid into the cylinders and let it sit for days.
Pulled the dampener.
Manually rotated engine many times.
Got all the extra Trans fluid out of the cylinders
Bore scoped the cylinders
Rebuilt both carbs.
Rebuilt both distributors
Put dampener back on
Set timing with an ohm meter
Replaced belts.
Rebuilt raw water pumps
Changed fuel filters.
Cleaned up anti siphon valves
Changed oil
Changed vdrive oil
Filled with new gas.
Filed carbs withgas through the vent.
They started right up.
Smoked like crazy for maybe 15 seconds while the oil burned out of the cylinders.
No problems
