2000 carver 356 aft cabin batteries
- mjk1040
- Been thanked: 248 times
Re: 2000 carver 356 aft cabin batteries
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
- mjk1040
- cpoint
Viper wrote:Source of the post Do you have two battery selector switches? If so, is one of them just an ON/OFF switch? If it is, that is most likely to turn off the generator battery power and the other switch is to manage the engine and house power sources.
Yes forward (near generator) there is a battery switch ON/OFF only. Under steps there is a switch 1/2/BOTH/OFF. So 1/2 is middle battery and back battery (under charger). That one has additional cables (3 of them) for black connection. So middle one must be #1, back one #2.
- cpoint
Now I need to figure out whats the best way to handle the settings on battery switch. Every time I think I get it, I keep getting confused. With weather getting colder, I think I will shut off refig when not there. I guess I can shut down DC switch on wall and battery switch OFF. That should make sure only bilge pumps to work if need be. I still need to figure out in my boat bilge and battery charger will still work if battery switch is OFF. Also I think dock power charger, charges all 3 batteries, sequentially or concurrently. Or if I have everything off (DC off), do I need to put battery switch OFF? because nothing should be drawing power.-
If you don't want anything powered up, turn off both the main breaker at the panel and the battery switch. This doesn't get you off the hook though, as mentioned before, you don't know what a previous owner did, they may have by-passed both the panel and switch. With those two switched off, just go around and try powering up all your DC loads, everything. If something powers up, you'll know it by-passes your mains. As long as these by-passed items are shut off though, you should be okay. You may have insignificant loads powered up all the time even with all switches off like the radio that will draw a tiny amount to keep things like presets in memory. Depends on how these sorts of loads were wired up.
- cpoint
