Boat will not steer, wheel spins freely
strokerking
- Vessel Info: 1981 Carver Aft Cabin
Re: Boat will not steer, wheel spins freely
- Been thanked: 491 times
Take a picture of the backside, or just tell us if there is two hoses or three.
Then I can link you to a parts explosion and you'll see what I am talking about.
strokerking
The pump only works when you give your vessels control to the autopilot.
The pump that moves the fluid is on your steering wheel.
Verify there is air pressure in the reservoir. There is a valve very similar to a tire valve. Depress it for a second.if air comes out, the gage good. You should some pressure, twenty five is spec I believe.
The bleeding procedure is to turn the steering wheel in one direction at least 75 turns in one direction, or until you get good resistance. Than 75 the other way. This may take five minutes, this may take for hours.
strokerking
Users browsing this forum: Google [Bot] and 51 guests
