WOT 24-26mph @4000rpm
- Been thanked: 601 times
Re: WOT 24-26mph @4000rpm
the merc fuel injected 454's run about 170 unless you push it up near the pins, then it will hit 180. It comes back down instantly when rpms are reduced. As others have mentioned, check your strainers, but it is most likely impellers that need replaced.
- mjk1040
- Been thanked: 245 times
- hausherrs
- Vessel Info: 1996 Carver 400
- Has thanked: 5 times
- Been thanked: 10 times
mjk1040 wrote:Source of the post You mentioned cleaning your exchangers. My I suggest you go to the Sea Flush web sight and watch how they clean and descale your water systems. Won't cost you $200.00 if you buy the Sea Flush unit and some descaler. Mike
Thanks Mike. I ordered a kit. It looks like you just attach the kit to the strainer housing, start the motor, and keep it topped off with descaler. Then shut it down and let it sit for 2-4 hours (From the bottle instructions)... Any preferences on descaler?
(Edit) I see that Im supposed to use a shop vac to push the descaler in. Not start the engine.
- mjk1040
- hausherrs
I have not replaced the fuel filters yet. I ordered them and they are on the way.
Im going to clean the strainers today. And descale the heat exchangers next week.
- mjk1040
- hausherrs
mjk1040 wrote:Check the descaler your buying, some of it calls to remove your anodes before introducing the descaler, that means your going to need some plugs too.
Got it. Do you recall how many there are? I recall seeing two per engine.
- mjk1040
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- hausherrs
tonyiiiafl wrote:Source of the post I have a 94 390 CPMY with twin Merc Bluewater's carbed. She runs @ 2800 about 14, and 25 GPH and 3300 about 18 @34GPH. I am on plane at 18. 160 T stat, and once up on 3400 it will run all day at 180 degrees with no issues. One has to remember, the heat exchanger has a small interface area! The alarm buzzers are set to chime in at 215, so even running at 200 is nothing to be concerned about, IMHO. As for WOT I hit 4 to 41oo AND top out at 28 to 30. Temp about 190. Cools right down after slowing down. Both new thermostats, and bottom is cleaned. I hope this helps someone. I am the second owner, sadly the first passed last July. He took loving care of this vessel and it shows.
Thanks for the info. The previous owner told me he serviced the heat exchangers a couple months before I bought it. I decided not to use the $80 bottle of barnacle buster yet. I pulled the caps off the strainers and they are spotless. Ill be replacing the fuel filters on the TBs today but other than that I’ll keep running it. The previous owner said that he had the props "Tuned". Hopefully that just means balanced and straightened.
Users browsing this forum: No registered users and 5 guests
