2000 carver 356 aft cabin batteries
- Been thanked: 654 times
Re: 2000 carver 356 aft cabin batteries
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
- mjk1040
- Been thanked: 248 times
- cpoint
- mjk1040
cpoint wrote:Source of the post......I used Displacement Connector (scotchlock connector)....
Shouldn't be using these. Most of them are also designed for solid wire only, not stranded wire.
- cpoint
cpoint wrote:Source of the post .... I soldered them basically now.
For future reference, in general, soldering is not recommended. By doing so, you create two stress points where the solder meets the unsoldered wire strands. These become stress points because the unsoldered points will flex while the soldered section won't. Eventually, under the right conditions, the point where the strands end and the solder begins will fail. It's like having a solid piece of wire which has no place in a marine application. If you're going to do this, spread out/minimize the fatigue load at the joint by using a long piece of shrink tubing and securing the wire immediately before and after the connection. This will cushion the load at the joint where it is most vulnerable. Best to simply use crimp connectors with built-in shrink tubing or add shrink tubing to regular marine connectors. Shrink tube connectors with adhesive are even better as they seal the wire and connection completely and make it waterproof. These are the only kind I carry on board now. More expensive but worth it unless you want to carry the same size in both types of connectors for different exposures. It just takes up less room to carry the one type.
- cpoint
- cpoint
