winterization 1994 390 CPMY/LENGHTY!
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: winterization 1994 390 CPMY/LENGHTY!
I did not get to AC and generator yet. I will attempt that next. The front AC is missing handle to open close valve from bottom into sea strain, so I need to fix that first. Than I know what to do. The back AC, I could not find the water source (sea strainer), where is the back AC water source? I did not see it under bed or under one of the doors in aft cabin floor.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
When I was doing it one of my dockmates asked why I bought so much of the pink stuff. I said I believe in overkill. I also pumped out my holding tank and then I ran 2 gallons through the pickup line and into the head and holding tank. For the shower sump I ran 1 gallon through it.
As to the rest I had the marina winterize my engines and AC/heat system. She is on the hard ready for winter. They will repair my transmission once they have finished winterizing all the boats going into storage.
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
cpoint wrote:Source of the post well, got the water system winterized, to be on safe side I added 13 gallons into the empty water tank. turned the water pump on and ran through all water outlets hot and cold until pink came out, including swim platform and ice maker (I will be posting other problem regarding ice maker shortly on other posting I have on ice maker). Also put a a gallon through both bathroom flooring to go through pumps below. including kitchen and two sinks and sink above ice maker in back. Pretty sure I covered all, oh yeah heads also, and per your instructions, emptied the hot water tank (drained), which had pink stuff. I did not bypass it though, at this point its empty and what was in there was pink stuff, since I ran quite a bit through it from water tank. I also forced pink stuff from dock supply side with drill pump and got that line winterized. Holding tanks may have a gallon or 2 of water that was in the heads at time, but I flushed at least 2 gallons in each head of pink antifreeze, hoping that should do.
Sounds like you got it all! As for the rear A/C strainer, on my 1994, and I would assume on most models our size, the units SHARE a strainer and pump. On my pump I see a "tee" where the source splits to the forward unit and the rear ward unit. Check it out!
***The only thing that concerns me is that you didn't say you emptied the hot water tank BEFORE you started the process. If that's the case, the tank was full of water which would have diluted the antifreeze (because the tank wasn't by-passed) and I would not trust leaving it in the water lines. If you emptied the HW tank first, then no worries. If my suspicions are correct, I'd be doing the whole thing over again to be safe or at the very least blowing out the entire system.
If the AC seacock handle is missing, I suspect the valve hasn't been moved in some time. If that's the case, it may leak once it's closed. If you're still in the water and the valve leaks, the leak dilute the antifreeze in the strainer and pump, and you'll have to revisit those items to ensure they are safe for the winter. If you get hauled out for the winter, you may be better off waiting 'till then before doing the AC system.
- cpoint
In regards to hot water tank, yes I had it run through faucets along with cold water as well. And when I ran pink stuff through it , it cam out of hot water faucets in all faaucets. After all that I drained the hat water tank by opening the release valve and got about quart of pink stuf that was in the hot water tank. So I think I am good on that.In regards to ac strainer, I am afraid that may be the case as well, but is there any other way I could empty it without opening the sea cock? I have drill pump with tiny hose, what If I use that to send to the bottom of sea cock and pump out the wter in it and fill with ante freze? that should work I think.
The strainer has a drain plug under it.
- Has thanked: 602 times
- Been thanked: 1310 times
- mjk1040
- Been thanked: 248 times
- cpoint
In regards to strainer, I was asking because the handle is missing and I don't want to risk opening/closing and that it does not close tight back. So I thought with shop vac, using a 1/4 hose put it all the way to bottom where the outside valve is and suck the water out, then fill the strainer and the hose heading to valve with antefreze? Not sure I am explaining it correcly?
I know the proper way would be to blowout the air from sea cock by briefly opeining the sea cock. And yes I have a shop vac, matter of fact got one that can blow out, as my old one did not.
mjk1040 wrote:Source of the post Cpoint, u have got 2 make up a bypass for that hot water tank and then u just drain it. U sure the 2 water lines won't connect to each other? Mine did on our 1998 355 AC. Mike
Mike I will look to see if I can bypass when I go back to it.
Or you can install one of the kits with valves on the market to by-pass the tank and never worry about removing the hoses again.
