My Season Is Over
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Re: My Season Is Over
I just returned from putting on the vents. I actually put in 10 of them because it was simple and they were cheap.
At $1.90 USD, the more the merrier! You simply stick them on and cut out a rectangular hole in the middle.
I put one by each of the port lights and will open those with the screen for interior ventilation and then spread out 4 on each side, forward to aft.
I never know these existed until now but will use them going forward. They are called "Weather Tight Self Adhesive Vents".
Here is the link: https://dr-shrink.com/shrink-wrap/vents/
https://mrshrinkwrap.com/1-x-2-x-12-poly-foam-padding.html
Basically the same material you'd get with a purchase of large electronics like a TV and such. If you ever run across that stuff, keep it for this reason, then it'll be free!
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
tomschauer wrote:Source of the post I don't shrink wrap. When I had express cruisers I just used the cock pit cover. With our 355, I just add extra support to the bridge canvas in case we get any significant snow.
I don't shrink wrap either. I just can't bring myself to cut off and throw away $1000.00. Too cheap I guess. I do remove canvas and strata glass and I made a cover for the deck and the front glass, enough to cover where snow might lay and melt and freeze and cause damage. The boat came with canvas covers for the helm and aft deck. So far so good, no ill affects.
