Need help troubleshooting Alarm on 8.1L Horizon engines
Cliffm
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 21 times
Re: Need help troubleshooting Alarm on 8.1L Horizon engines
Postby Cliffm » September 9th, 2019, 10:16 am
tomschauer wrote:Source of the post Check your transmission fluid. High trans temp will also give you an alarm
This is a good tip, that I hadn't thought of, and there is no trans temp gauge at the helm.
thanks!
cliff
Postby km1125 » September 9th, 2019, 11:17 am
Wow, sounds like it very well could have been a tranny temperature issue, with the burned fluid. I'd keep a close eye on that, as the new fluid might allow it to lock up a little more (averting a temperature alarm) but might still slip and wear the clutches, putting you right back where you were but with a worn out transmission.
mhanch
Vessel Info: 2000 Carver Voyager 374
Twin Gas Mercruiser 8.1L Horizon engines (2007 Repower)
Has thanked: 5 times
Been thanked: 6 times
Postby mhanch » September 9th, 2019, 12:43 pm
km1125 wrote:Source of the post Wow, sounds like it very well could have been a tranny temperature issue, with the burned fluid. I'd keep a close eye on that, as the new fluid might allow it to lock up a little more (averting a temperature alarm) but might still slip and wear the clutches, putting you right back where you were but with a worn out transmission.
Yes, I'll have to keep an eye on this. I've heard from folks that the Velvet Drives are pretty bulletproof, so here's hoping that holds true **crosses fingers**
Postby tomschauer » September 9th, 2019, 7:05 pm
Hate to say it, and hope I'm wrong, but..... burnt fluid means you have something bad going on in there. It should never get burnt.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » September 9th, 2019, 7:38 pm
You are correct, burnt fluid is not a sign. But, lets stay positive.
mhanch
Postby mhanch » September 9th, 2019, 11:49 pm
I'll keep an eye on the fluids. I don't feel anything odd in the running, so I'm keeping a positive attitude. I hear that helps. :)
Postby Viper » September 10th, 2019, 6:38 am
When was the last time that fluid was changed, and do you know if she's ever had an impact?
mhanch
Postby mhanch » September 10th, 2019, 10:51 am
Viper wrote:Source of the post When was the last time that fluid was changed, and do you know if she's ever had an impact?
Well, the boat is new to me, so I can't say for sure either way. When we got the boat, It looked like it just didn't get a lot of use. I don't see any signs of impact.
Has thanked: 603 times
Postby bud37 » September 10th, 2019, 12:55 pm
So because there is some discussion about the fluid........when you checked the fluid before you changed it....how would you describe the color on the dipstick.....pinkish,used oil color,or honey color.?
Do you have v drives with the trans/drive ( no shaft between ) attached directly to the back of the engine ?
mhanch
Postby mhanch » September 10th, 2019, 2:08 pm
bud37 wrote:Source of the post So because there is some discussion about the fluid........when you checked the fluid before you changed it....how would you describe the color on the dipstick.....pinkish,used oil color,or honey color.?
Starboard was Used oil color with some pinkish color, Port (with the alarm) was used oil color with almost no pink. Both are straight drive (no v drive).
After the flush and running, I checked both again and they are pink, no used oil color.
