Window weather stripping (Cat Whisker) replacement
Been thanked: 1111 times
Re: Window weather stripping (Cat Whisker) replacement
Postby km1125 » October 27th, 2021, 4:43 pm
tonyiiiafl wrote:Source of the post How did you get the entire track done? Did you do 1/2 then slide the window back and do the other half? And the fixed panel? Thanks this will make it easier for us!
On mine both window panels slid, but I just slid the one window all the way open and pulled on the old stuff and it all slid out of the track. As I put the new stuff in place, I snapped about 8" in, slid that back, then did another 8", then slide that back and continued unit the end was all the way to the back of the track, then trimmed and snapped the rest in place up to the front of the track.
Honestly, the hardest part of the job was cleaning out the track once I got the old stuff out. I could not believe all the crap that was crusted underneath the old stuff. Once I got it clean it drained VERY nicely though. Putting the new pile in blocks most of the water from getting into the track and the remaining that does will run out the drains easily. I used to have issues with heavy rain where the track would overflow and leak inside the boat. NEVER happened once I cleaned the track and put the new pile in.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » October 27th, 2021, 5:01 pm
Thank you. I hope to get this done aaap as mine leak inside also
Great Britain
PossiblyPaul
Vessel Info: Hornbill III
1988 Carver 2827 Voyager,Volvo Penta TAMD31 engines.
Ardglass Marina, County Down
Has thanked: 48 times
Been thanked: 6 times
Postby PossiblyPaul » November 3rd, 2021, 8:30 am
Thanks for that, it'll make it less of an ordeal in the coming months of repair and maintenance.
Funga Safari
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Postby chpsk8 » November 4th, 2021, 6:24 pm
It's totally worth the effort. I could tell which side of my boat was finished by how much less noise and breeze was coming in on that side. Not hard, but tedious and dirty. At least mine was, so so so dirty
dtcom
Vessel Info: 1993 Mariner 330
Has thanked: 4 times
Been thanked: 3 times
Postby dtcom » January 16th, 2022, 9:39 am
Does anyone know what size the pile weather-stripping is on a 1994 Carver Mariner 330?
dtcom
Postby dtcom » January 16th, 2022, 10:00 am
I am looking to replace the "zipper piling" in the window tracks on my 1994 Mariner 330. Does anyone know the size to order?
dtcom
Postby dtcom » January 16th, 2022, 10:01 am
tonyiiiafl
Postby tonyiiiafl » January 16th, 2022, 2:19 pm
Here is what I bought. .Most common size and also what Taylor Made
said was in their window frames.
dtcom
Postby dtcom » January 16th, 2022, 2:25 pm
Thanks. Different boat, but I guess I'll try that size.
tonyiiiafl
Postby tonyiiiafl » January 16th, 2022, 3:56 pm
Different boat but it snakes into the side channels and most of Taylor Mades windows use this particular stripping.
