E01 error Code on Salon hvac
Re: E01 error Code on Salon hvac
- Been thanked: 1113 times
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
km1125 wrote:Source of the post As Viper notes, that is probably programmable. Do you know exactly which controller you have? Some look similar but have different versions that have different programming techniques or features. Some you can differentiate on whether or not it has a "snowflake" icon on the button or case. Post a pic of the controller if you don't know, and someone may be able to ID it by sight.
By the “controller”, are you referring to the wall mounted thermostat or the box mounted next to the compressor/air handler unit?
I thought the two thermostats and units were identical except for the BTU sizes. I’ll look and post pics of the thermostats when I go back to the marina. It’ll be a couple weeks as we’re headed out of town to visit grandkids.
I read through the manual, but only have one manual and can’t remember if it’s the Salon or Fwd unit. Both units are Webasto and are new, installed last summer.
Thanks for the guidance!
Standby.
1979 Caravelle 18’
Mikwallace wrote:Source of the post
Yes.
They're referred to as a "controller" now because they do so much more than just an on/off for temperature like the old "thermostats".
The controllers can do things like varying fan speed and controlling humidity rather than just heat and cool.
- Has thanked: 603 times
- Been thanked: 1311 times
http://www.techwebasto.com/old/marine_m ... Manual.pdf
- Mikwallace
This is the Salon/Aft HVAC 16k BTU unit controller.
It would not let me post two pictures??
1979 Caravelle 18’
- Mikwallace
bud37 wrote:Source of the post Does your stuff look like this ....? Check link below.
Yes, it looks like that.
I have an installation Manual but not the “Quick Reference Operation Guide”. Maybe there’s info in it to help. Also, I’ll print that and carry on-board.
1979 Caravelle 18’
- Mikwallace
My Remote is different. My remote is type: YX1F
The controller looks the same.
1979 Caravelle 18’
"Press the FAN button, the fan speed will change in the following order:
→ HIGH →MID → LOW → AUTO"
Users browsing this forum: Google [Bot] and 29 guests
