Window weather stripping (Cat Whisker) replacement
dtcom
Vessel Info: 1993 Mariner 330
Has thanked: 4 times
Been thanked: 3 times
Re: Window weather stripping (Cat Whisker) replacement
Postby dtcom » January 16th, 2022, 4:19 pm
tonyiiiafl wrote:Source of the post Different boat but it snakes into the side channels and most of Taylor Mades windows use this particular stripping.
Thanks! I'll try it.
dtcom
Postby dtcom » January 20th, 2022, 5:34 pm
Does anyone know if the pile weatherstripping is just on the bottom, or all around the window frame?
Been thanked: 1111 times
Postby km1125 » January 20th, 2022, 6:04 pm
Not sure on that boat, but on mine it was all the way around, both inside and outside.
KandJ72
Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process
Has thanked: 20 times
Postby KandJ72 » May 16th, 2022, 2:15 pm
I was hoping to find some information on this. Our 76' Mariner leaks EVERY time we get even light rain. I've tried clearing the drains and pulled alot of nastiness out yet the channels still fill up and dump into the salon. There's no cat whiskers at all in there and I've been thinking that's just the way it's always been.... Silly me lol.... Or did they not use it that far back?
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Postby Phrancus » May 16th, 2022, 2:22 pm
Check for all places where the water flows to. In my case the corner of a front window turned out to look fine but the caulk let water through and created quite a puddle in little time. Put some clear tape over suspected areas and figured it out eventually where it got through. If you look at the corners it looks fine, but apparently it goes underneath and finds its way.
The whiskers help to keep the glass in place, reduce wind and dirt going through but do not seal anything. You may have some caulk that keeps the frame in place that lets it through. had the same at the head, put clear (wide, thick) tape over suspected areas and thus found the route.
