Nova Kool RFU8000
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Nova Kool RFU8000
I seems that my fridge no longer runs on AC when we are plugged in to shore power. It just continues to run on DC. Not a huge problem better to be this way than opposite.
I am guessing that there must be an AC to DC converter in there. I will have to take it out and start poking around next time up at the boat.
If I am able to isolate problem who would be the Canadian source for parts? Nova Kool (so far) does not seem to be interested enough to respond to my enquiry.
Fraser
- mjk1040
- Been thanked: 248 times
Re: Nova Kool RFU8000
- feeez
I am familiar with Northland. I will have to clarify the specs but there are lots of AC / DC power supplies out there. Digikey sells all kinds but I will need to know what wattage is required to run the compressor. I guess I will be heaving that behemoth out of the cabinet this week and see whats back there.
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
T-Merc 350 Mag MPI (300hp)
- feeez
Viper wrote:Source of the post Fraser, check the simple things first before jumping the gun; check that you're actually getting 120V to the board, look for a fuse, etc...you know the drill.
Will do.... I found the trouble shooting guide and I will run the drill!!
Kenny, Thanks for the reminder on the GFI. That happened to us last season, couldn't figure out why our Coffee Maker (911 situation) and microwave wouldn't power up. Sure enough the GFI had popped.
Cheers All
Fraser
- feeez
We got in the water (finally) this past week. I got the fridge up and running and everything seemed AOK, my beer was cold!!! After it had been running for a day I noticed that it would come on, run for about a minute, stop and then resume running. It would eventually turn off properly (I could hear the "click" of the thermostat). As time went by this "short cycling: got more persistent to the point that it was on and off, on and off. I decided to shut it down as I did not want to leave the boat with the fridge doing that for days on end thinking that it would not be good for the compressor.
Cheers
Fraser
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
feeez wrote:Source of the post I thought I would reopen this thread about my Novacool Fridge. I did confirm the Power supply was dead but it was running fine without it.
Cheers
Fraser
Fraser, did you figure out the cause?
