House Battery Charging Issue
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 87 times
Postby denpooch » August 31st, 2020, 10:59 am
Hey Folks I hope you can help with this one.
I have discovered that my house battery is not charging while underway. I checked and the alternators are working. The starting batteries are charging but for some reason the charge is not making its way to the house. The house battery does in fact charge when plugged in dockside electric. All wires seem tight.
One question is how is the battery wired so that only the house battery will discharge for d/c demand while the starting batteries do not discharge, yet is able to accept alternator charging.
I there some solenoid or switch that can be defective?
Any thoughts and insight are much appreciated. Thanks.
Been thanked: 646 times
Re: House Battery Charging Issue
Postby g36 » August 31st, 2020, 11:41 am
What boat model? There's probably a selector switch somewhere maybe under a stair like my 405 or ? . Battery charger has multiple legs so different batteries are charged when plugged in. Depending on battery selector switch alternators could be working but selector swich has house cutoff from charge. Never now how a previous owner may have changed stuff around either.
darrenlife
Been thanked: 36 times
Postby darrenlife » August 31st, 2020, 12:17 pm
You may also have a battery isolator. Both alternators are likely going to the input side of your isolator and should be 3 output legs, one to each starting battery and one to your house?
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » August 31st, 2020, 12:27 pm
To answer we will need a little info.....I assume your disconnect for the house battery is on , do you only have one house battery ?, how have you determined it is not charging from the engines ? Perhaps the battery is just dead or shorted, when on shore power your charger is on therefore 12 volt DC is available to the house loads, the same underway if you run the genny or the engines are running.
The tell would be to disconnect your shore power, gen off then try DC house loads, put multimeter on the house battery then start an engine and see what registers, or disconnect the leads on the house battery and have it load tested.
Also like g36 states, ya never know what has happened before you..plus consider what darrenlife says...good luck with it...
denpooch
Postby denpooch » August 31st, 2020, 4:31 pm
The boat is a 2005 Mariner 36.
I let the battery 'run down' yesterday and put a meter on the battery and started the engines. No movement. I do know the alternators are working from dash voltmeters. The battery is brand new this season and has been tested.
I am gonna check all circuit breakers and look for an isolator.
Thanks folks, I will keep you posted on progress.
Been thanked: 1180 times
Postby Midnightsun » August 31st, 2020, 4:46 pm
You must have some battery switches. Are they simply the on/off type?
denpooch
Postby denpooch » August 31st, 2020, 6:19 pm
I FOUND THE PROBLEM!
The battery has 3 red cables connected to positive terminal of the house battery. The largest seems to feed the system. Second seems to be the input from onboard charger. The last is inbound from the isolator. This cable went from the terminal to a breaker and that breaker needed to be reset.
I checked voltage before and after starting the engine. She is charging!
Thanks for your advice.
Postby Midnightsun » August 31st, 2020, 7:21 pm
Gotta love an easy fix and happy ending. Not often it cost zero boat dollars. :-D
