Removing saloon door
- jfwatson3
- Vessel Info: 2000 Carver 396
I have a 2000 Carver 396 aft cabin, that has sliding saloon door and separate sliding screen. The track and wheels on the screen have become so fouled it does not easily open or close. So I need to remove the door and then screen to clean the track and probably replace the slide wheels. The question is how to best remove the sliding door. Referring to the attached pictures (), I think the following will allow me to remove the door, but I'm not sure:
(1) remove the two sets of two screws from the top of the door to release from the top track wheels.
(2) remove a set of screws (looks like 3 or 4) along the bottom of the door to release from the bottom track wheels.
(3) the door does not look like it would have room to lift out unless the trim piece at the lower left of the foot well is removed; it appears to be removable with a single screw (and cutting the caulk).
The above is hoping that the seat above the door, the cabinet to the left of the door, or the stainless rail to the right of the door do not need to be removed in order to remove the door.
Any experience, ideas and tips appreciated.
Thank you.
--Jim
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
Re: Removing saloon door
- mjk1040
- Been thanked: 248 times
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 21 times
Cleaning the rollers is much like cleaning the old roller ball mouse, scraping off all the accumulated residue.
hope this helps, good luck!
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
I ran across some info a while back about someone removing this door and replacing the "plastic" slides with actual rollers. I haven't been able to find that thread yet, but I'll keep looking.
Thanks!
Kyle
2002 Carver 396
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
This subject is dear to me as I slightly tore a tendon in my should last August which at some point may require surgery from operating this door. I will do anything to fix this. Please keep us informed.
Carverlvr2
- Vessel Info: 2004 Carver 366, VP 8.1’s
1979 Searay Sundancer 260 - Location: Shelbyville, IL
- Been thanked: 25 times
- KyleR
2002 Carver 396
2002 Carver 396
Users browsing this forum: No registered users and 57 guests
