Interior door levers
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » March 5th, 2021, 10:16 am
Over time I have noticed that some of the levers on my interior doors are dropping down and seem to have lost their tension. I would like to fix them. Has anyone looked into this issue and was wondering if you could assist me in how to rectify the issue, short of replacing the door levers.
Thanks in advance
Greg
Re: Interior door levers
Postby Midnightsun » March 5th, 2021, 10:24 am
Not knowing what you have I would try to open them up and see what is in there. Most likely just a spring that is tired and need of replacement.
Postby km1125 » March 5th, 2021, 11:21 am
and you might be able to swap some around so that the ones on the left side of doors get swapped for the ones on the right sides of doors so that the wear is evened out over time.
Postby Viper » March 5th, 2021, 12:39 pm
Greg, when I first got the 3807, all the door handles sagged. It is a an internal spring as Hans mentioned. I removed the complete assemblies, dropped them off at a local locksmith and had them back in time for the following weekend. They usually have a selection of different springs they can use or modify to do the job. Worked great and was at a very reasonable cost.
Icango560
Vessel Info: 2004 Carver Voyager 560, 675 Volvo’s.
Postby Icango560 » March 5th, 2021, 4:06 pm
I just reattached the old spring at the next coil.
Good luck
Postby Midnightsun » March 5th, 2021, 4:27 pm
Icango560 wrote:Source of the post I just reattached the old spring at the next coil.
Good luck
Exactly what I was thinking. :down:
Grafunkus
1985 3607 Carver Aft Cabin
Has thanked: 63 times
Been thanked: 32 times
Postby Grafunkus » March 6th, 2021, 8:07 am
As a quick fix on our Mariner, I used a spring from an old click pen. Seemed to work just fine!
Rmscarver53
Vessel Info: 53 Carver Pilothouse
Postby Rmscarver53 » April 28th, 2021, 5:29 pm
I have the same problem on my interior doors... the springs have broken. It seams to be a sealed square piece I cant get to the spring to replace it.... any ideas????. I will try to post a picture soon.
Tireless
Postby Tireless » April 28th, 2021, 7:02 pm
I still haven’t had a chance to check mine out. I can’t go to the boat. Would love to hear how you make out Rmscarver.
Greg
C360SS
Vessel Info: Carver 360 SS
Postby C360SS » January 17th, 2022, 6:20 pm
Rmscarver53 wrote:Source of the post I have the same problem on my interior doors... the springs have broken. It seams to be a sealed square piece I cant get to the spring to replace it.... any ideas????. I will try to post a picture soon.
How did you end up fixing this issue? I have the same problem with the sealed square mechanism piece. :banghead:
