Isolator and Zincs
schooner
Vessel Info: 2001 356 Motor yacht
Isolator and Zincs
Postby schooner » April 1st, 2022, 2:46 pm
Have a 2001 356 aft-cabin. Do I need to have zincs on my tabs ?
Where is the Galvonic Isolator ?
Re: Isolator and Zincs
Postby g36 » April 1st, 2022, 2:53 pm
I'm in freshwater with a 97 405. I don't have any sacrificial anodes on my trim tabs. Where are you boating?
Postby Viper » April 1st, 2022, 5:55 pm
If you have a galvanic isolator, they're often mounted behind the breaker panel. It's not a requirement to have anodes on your tabs but it is an option. What do you currently have for anodes?
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » April 1st, 2022, 7:18 pm
I boat in fresh water and I do have anodes on my trim tabs. They are mounted on the top side of the tab.
Greg
Has thanked: 603 times
Postby bud37 » April 1st, 2022, 7:27 pm
schooner wrote:Source of the post Have a 2001 356 aft-cabin. Do I need to have zincs on my tabs ?
You should have 2 galvanic isolators, one for each shore power line, wired in the green ground....they are most likely behind the 120vac panel. Depends on where your boat is, we always had anodes on the tabs, the shafts and a divers dream on the transom.
Where do you boat ....fresh water or salt ?
V12diablo
Vessel Info: 2001 Carver 356 Aft Cabin
Been thanked: 13 times
Postby V12diablo » April 2nd, 2022, 8:05 pm
On my 2001 356, it is located in the master birth behind the right head board, I do have zincs on my tabs and I am in freshwater.
Jason
seaweed
Vessel Info: 2001 Carver 356 AC
Been thanked: 3 times
Postby seaweed » April 3rd, 2022, 1:06 pm
I'm in fresh water and on my 2001 Carver 356 Aft Cabin, I have magnesium anodes on the shafts, tabs and hull.
Use zinc for salt water.
