Cored hull?
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Cored hull?
Postby tonyiiiafl » June 16th, 2023, 7:47 pm
I was just gifted a new Ray CHIRP module side scan CP200 that wil work with my e series displays, Light House 2 software. I have an air ar thru hull transduer A A66091. I am looking for a zCHIRP transducer, preferably a shoot thru hull type. All the ones I have seen are for cored hulls. I believe my 1994 390CPMY is a solid glass hull? I know the stringers are hollow composite. Any ideas?
Has anyone used the transom mount transducers? Not a lot of room there where it could be mounted with not interference from teh wash/wake?
Thanks!
Re: Cored hull?
Postby Viper » June 16th, 2023, 9:55 pm
Don't use transom mount, they're not ideal for inboard applications. Are you sure the in-hull ones you've seen are for cored hulls? Usually they prefer you remove the core for those. Has something changed recently?
tonyiiiafl
Re: Cored hull?
Postby tonyiiiafl » June 17th, 2023, 4:32 am
I am doing more research. From what I even saw only one transducer is compatible with the CP200. Many others are good for the CP100, 300 and 350.
I am digging in.
Re: Cored hull?
Postby km1125 » June 17th, 2023, 9:13 am
I'm not aware of any shoot-though-the-hull transducers that can work with a cored hull. If you're seeing that somewhere please post the links so I can follow up on it.
kgarguilo
Vessel Info: 1999 Carver 406
Has thanked: 197 times
Been thanked: 55 times
Re: Cored hull?
Postby kgarguilo » June 17th, 2023, 9:39 am
See my recent post on 406 Navionics upgrade
viewtopic.php?f=10&t=7707&p=60463#p60463
I have the Garmin Transducer GT54UHD-TM and a Airmar M66 transducer (Re-used existing for 50/200 Mhz).
I get a great result at all speeds withe the TM. If you want to see a video, I can make one on my next outing.
Kevin G.
1999 Carver 406
Re: Cored hull?
Postby Viper » June 17th, 2023, 10:21 am
I've attended Garmin, Raymarine, and Furuno training and seminars on Airmar product and the recommendations/consensus are that transom mount units are "not ideal" for inboard applications. They are best for outboard and sterndrive applications. That's not to say they won't work under the right conditions and a careful installation on inboards but the preference for inboards is the thru-hull, in-hull designs. Where practical, you could even take an appropriate transom mounted design and epoxy it inside the bilge on some applications, depends on the unit.
Has thanked: 603 times
Re: Cored hull?
Postby bud37 » June 18th, 2023, 2:18 pm
If you want to find out if it works as shoot thru......just pick your spot following the guidelines , put the ducer in zip lock bag full of water and put in contact with the hull, see if you get a good result.
FYI.....I have epoxied a lowrance wide angle transducer to the inside of a cored hull and it worked just fine. The above is the method I used to find a good spot first.....good luck.
Hoplite808
Vessel Info: 1988 Carver 3227 Convertible
Been thanked: 8 times
Re: Cored hull?
Postby Hoplite808 » June 18th, 2023, 3:49 pm
bud37 wrote:Source of the post If you want to find out if it works as shoot thru......just pick your spot following the guidelines , put the ducer in zip lock bag full of water and put in contact with the hull, see if you get a good result.
I second this method. I’ve secured more than a few transom mount transducers with clear silicone adhesive to the bottom of the bilge and got accurate readings for depth. Water temp readings will be close enough for government work.
