Courtesy Light Switch Location
- mparks813
- Vessel Info: 1992 Carver 33 aft cabin, Volvo Penta KAMD-42A diesels.
- Has thanked: 5 times
I am new to boating and as a month ago became an owner of a 33 Aft Cabin (diesel, Volvo Penta Kamd-42A). I am trying to locate the switches for the courtesy steps leading down to the aft cabin. There is also a switch inside the rear deck shower hatch for lights. When I flip those switches, nothing happens. Any thoughts on where the mystery switch is?
Matt P
- Been thanked: 1113 times
Re: Courtesy Light Switch Location
I'm sure someone with a similar model will give you some clues on the switches.
- Has thanked: 602 times
- Been thanked: 1311 times
- plittle2005
- Has thanked: 16 times
- Been thanked: 37 times
On my '92 33' AC, enter the main cabin, turn 180 deg, you will see two switches on the bulkhead just to the left of the entry handrail, right hand side of the aft cabin entrance.
One switch is for the courtesy lights, the other for the cabin ceiling recessed lights.
The switches for the aft deck overhead lights and the deck/bridge courtesy lights are in the locker between the main cabin steps and the bridge steps on the aft deck. Look up underneath the top lip, they are way up in there, out of line of sight.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
plittle2005 wrote:Welcome aboard! I envy your diesels! Nice rig!
If I’m not mistaken, my 356 is just a slightly larger, updated version of the 33 aft and that is where my switches are as well.
And agree with above, your bulbs may simply have burned out. If they are, I suggest replacing with LED equivalents as well as all your 12v bulbs. Those halogens use a lot of battery power and are very hot. LED’s are much cooler and use a fraction of the battery power.
- mparks813
- mparks813
- Aflix
- Vessel Info: Carver 33 '92
Aqua Fiber 42 1976 - Location: Nashville
- Been thanked: 2 times
I have a switch I am not sure what it controls. It is the middle switch on a three gang panel, on the side as you go down to the galley. The switch on the left and on the right of this one, both work and control map lights. Its the one in the middle Im stuck on...
Any help would be greatly appreciated.
Alex
Hopefully someone with the same boat can say for sure.
- buster53
