Closed cooling overheating - solved
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Has thanked: 5 times
Been thanked: 7 times
Postby Youghster » July 10th, 2024, 5:58 am
In the interest of saving some fellow boater a trip "down a rabbit hole", I offer. My 1995 Santego 5.7 TBI had overheating problems, especially at idle in long no wake zones. After impellers (several), one new / rebuilt, raw water pump, professional heat exchanger cleaning, new thermostats - I finally got serious about pulling some hoses and troubleshooting. It appeared that the engine coolant circulating pump was weak (no noise, no leaks). So I hustled on down to Carquest and picked up a replacement for about $50 and a couple gallons of antifreeze. Port engine now rock steady at 170*. Starboard replacement pump is now in hand and going in ASAP. I hope this is helpful to somebody.
Has thanked: 469 times
Been thanked: 1765 times
Re: Closed cooling overheating - solved
Postby Viper » July 10th, 2024, 6:42 am
:down:
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » July 10th, 2024, 10:23 am
Curious if you did (or will) pull the back off the water pump to see what was going on. I heard of one where the impeller was coming loose on the shaft.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 487 times
Been thanked: 206 times
Postby pepmyster » July 10th, 2024, 5:02 pm
When I was working at Chrysler, I found once a water pump problem, over heat like the one your stating. All looked great, took off the water pump, and the impeller on the shaft was spinning free. Glad you found your problem!
Jay Fusaro
Vessel Info: 1998 445 Aft Cabin
Has thanked: 75 times
Been thanked: 3 times
Postby Jay Fusaro » July 10th, 2024, 7:12 pm
Well done!
Jay Fusaro
AquaVilla
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Postby Youghster » July 12th, 2024, 8:12 am
I did not pull the back off the old water pump - yet. All the guys on the dock are wondering too.
Raven
Vessel Info: 2005 360 Mariner
Postby Raven » July 19th, 2024, 4:25 pm
is the impeller in the water pump replaceable? or do you have to replace the whole assembly?
I am having the exact symptoms at idle( heat guage creeps up) but at higher rpm it cools down to normal
Postby km1125 » July 19th, 2024, 5:05 pm
Raven wrote:Source of the post is the impeller in the water pump replaceable? or do you have to replace the whole assembly?
You might want to start a new thread for your issue, or you'll get confusing responses mixing up your issue with the OPs.
But -to answer your question- no circulating pump I've seen has a field-replaceable impeller. They are usually pressed on the shaft with a hydraulic press. But if you were referring to the raw water pump, then yes, those always have replaceable impellers.
