Replacement Mooring Chain for a 1999 445
Alastair MacGregor
Vessel Info: "BAD MONKEY'
1999 445
Cummins
Safe Harbor Ventura Isle
Ventura, CA
Has thanked: 17 times
Postby Alastair MacGregor » January 8th, 2025, 5:55 pm
New to this size boat
Ran out my chain and found it to only be 175 feet long. Last few owners didn't do much with the boat. Wanting to replace with 300'. The current chain appears to be 8mm 1.5" links stamped LH. Local shop wasn't sure of the origin suspects its a foreign make.
Any recommendations for replacement that will be compatible on my windlass?
Re: Replacement Mooring Chain for a 1999 445
Postby Viper » January 8th, 2025, 7:34 pm
It depends on the brand and model of your windlass. Check the rope and chain spec for that particular unit to ensure you're getting the correct chain size.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » January 8th, 2025, 9:09 pm
Before we purchased new chain recently, I took my gypsy off my windlass (Maxwell Freedom 800) and took it to West Marine to ensure the correct fit. Our chain was 5/16" and we went with the Grade 43 (G4) High Test chain.
Do you know the model of your windlass? There are several varieties of chain (e.g. some for mooring, some with longer links, some with shorter links, some designed for windlasses) so do your due diligence before purchasing.
Good luck!
Kyle
MV Verity
2002 Carver 396
Alastair MacGregor
1999 445
Cummins
Ventura, CA
Postby Alastair MacGregor » January 12th, 2025, 11:53 pm
Thank you, will check it out
Postby Viper » January 13th, 2025, 7:26 am
Which brand and model windlass do you have? The Maxwell Freedom 800 was used a lot back then. If that's what you have, it's 5/16" G4 chain.
Users browsing this forum: No registered users and 56 guests
