Head maintenance
- wbriese76
- Vessel Info: 85 carver mariner 28
Head maintenance
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: Head maintenance
I'm guessing you have a blockage. You mght just go ahead and rebuild it while you take it apart.
Our first boat had a manual pump and I converted it to electric. But that was 40 years ago.
- Been thanked: 1113 times
Some have a valve that will allow you to pump water in while pumping out, but then stop water pumping in while you pump it out. On some they have a "joker" valve or flapper on the output to the tank that may be damaged which will cause the pump-out to be slower than normal.
