Blower Motor Replacement Tips on 36M
- JRoberts
- Vessel Info: 2005 Carver 36M, Coeur d'Alene, ID
- Has thanked: 13 times
I've got a 36M with the factory 12,000 BTU AC unit under forward stateroom bed (Picture of it: https://photos.app.goo.gl/V5sdRhVm9bnfR1n49), and the blower motor is breathing it's last breaths as we speak. I was looking to see if anyone on here has done a blower replacement on one of these units, or something similar, and had any advice on what direction to go.
It appears to have some rivets holding the outlet into the rest of the assembly as well as some hex bolts on the edges. Is that all I have to remove in order to get the motor out?
Or would it make more sense to just replace the entire unit, given it's age?
Any input is greatly appreciated, thank you!
Here's a listing of what looks to be the same thing for reference: https://maxmarineoutlet.com/product/tay ... nditioner/
- JRoberts
Re: Blower Motor Replacement Tips on 36M
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Kyle
2002 Carver 396
- JRoberts
- KyleR
2002 Carver 396
Ok, thanks. any tips on replacing that?
Not much....fortunately I was able to disconnect the air discharge ducting and slide the unit out enough to do the work. Basically disconnecting the power and then unscrewing the applicable screws. I didn't have to mess with any of the raw water connections. Pretty straightforward but every installation is different! Good luck!!
2002 Carver 396
