Exhaust fumes
- Pha8
- Vessel Info: 2002 Carver 346
- Has thanked: 32 times
- Been thanked: 5 times
Exhaust fumes
EDIT: Their are 2 switches for the blowers.
1 on the helm station
1 on the DC Main panel
Both have to be turned on??
Thought both switches would control all blowers?? Odd
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Exhaust fumes
Not sure what is setting the engine room fume detector off.....be careful here as they ( the detectors ) look for explosives like gasoline fumes so again be very sure you do not have a fuel leak from engine fuel systems or fuel tanks although very high levels of CO are flammable. Check all your exhaust hoses all the way to the hull outlets for muskrat damage, you maybe would have water in the bilge from any leak like that though IMO.
As for the CO.....with the blowers and the engines running you are evacuating a lot of air from the engine room so you maybe getting a loop going that pulls exhaust back in thru the aft from outside with certain wind directions. Again be very careful here as CO can be a silent killer.
Check your engine room vents to be sure the inlet vents are clear and letting in fresh make up air.
It is good you are taking this serious.......good luck and be careful.
- Pha8
Re: Exhaust fumes
The boat is new to me. When I transported the boat 5hrs to its new home, both alarms were going off the whole time. I just replaced both impellers and ran each engine after replacing the impellers and both times, both alarms went off. No smell of gas, but I could smell exhaust fumes in the aft cabin. Blowers going and engine bay floor (Salon floor> 1 panel) open.
- Been thanked: 1113 times
Re: Exhaust fumes
And you can try to run one engine at a time to see if the issue is related only to that engine.
- waybomb
- CYO Moderator
- Been thanked: 491 times
Re: Exhaust fumes
- sbb2112
- Vessel Info: 1982 Carver Monterey 2687
260 Mercruiser / Mercruiser Alpha sterndrive
1992 Carver 350 ACMY
454 Crusaders with V-drives - Location: Michigan
- Has thanked: 2 times
- Been thanked: 10 times
Re: Exhaust fumes
- Rocketman
- Been thanked: 24 times
Re: Exhaust fumes
CO monitors are only good for about 10 years.
Check where your exhaust port is at relative to your blower input. I have seen where they are too close to each other and the intake pulls exhaust right back in.
If so, you may need to reverse that one (most boats have multiple blowers) to make it blow out instead of in. You are just trying to ventilate the compartment. One blowing in and one blowing out is sufficient to vent.
