Salon AC does not have cold air
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 23 times
Postby tgebler » June 30th, 2025, 9:05 am
My 2000 396 Aft Cabin has three AC units. Two of the three work fine but the salon AC runs and blows air but it is not cold. Any suggestions?
Been thanked: 646 times
Re: Salon AC does not have cold air
Postby g36 » June 30th, 2025, 11:45 am
Not much to go on . What manufacturer of unit? Do all 3 run off the same water circulating pump? Or does it have its own? Is it icing up? Have you tried seeing if there's a high pressure cutout that may be tripped? Try starting the unit and let it run then carefully touch the outside of compressor see if its getting hot or just stays room temp. Tried running in heat mode?
Been thanked: 284 times
Postby buster53 » June 30th, 2025, 12:15 pm
Try this and let us know what happens, when you adjust the temp either up or down, can you hear the compressor turning on/off?
g36 has a good suggestion, turn up the temp enough to kick it into heat mode? What happens? Can you hear the compressor kick in? After a minute or two, are you getting heat?
Been thanked: 601 times
Postby tomschauer » June 30th, 2025, 3:14 pm
If the unit is original, there is most likely a reset button on the compressor discharge line. If this is tripped, and the unit starts after it is reset, you more than likely have a low water flow issue.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » June 30th, 2025, 8:24 pm
Check the basics; water flow, is the compressor actually running, is there good air flow around the unit/evaporator, are the evaporator fins clean?
Postby buster53 » July 5th, 2025, 2:41 pm
g36 wrote:Source of the post Not much to go on . What manufacturer of unit? Do all 3 run off the same water circulating pump? Or does it have its own? Is it icing up? Have you tried seeing if there's a high pressure cutout that may be tripped? Try starting the unit and let it run then carefully touch the outside of compressor see if its getting hot or just stays room temp. Tried running in heat mode?
Any progress on your problem?
tgebler
Postby tgebler » July 7th, 2025, 11:34 am
Solved, thanks. I pushed the reset button on the A/C it it worked. Thanks.
