2001 Carver 466- Vinyl/Rubber extrusions for window glazing
Victorboat
Vessel Info: 2001 Carver 466
Postby Victorboat » August 29th, 2025, 10:11 am
Hello folks,
I have a 2001 466 Carver that needs to have the vinyl/rubber glazing strips replaced. Do you have a source for the vendor that Carver uses for these extrusions? I need the continuous strips that fit between the glass and the aluminum frames/extrusions. Any help would be greatly appreciated.
Thank you,
Victorboat
Re: 2001 Carver 466- Vinyl/Rubber extrusions for window glazing
Postby Viper » August 29th, 2025, 10:23 am
Welcome aboard. Try Bomar/Pompanette.... https://pompanette.com/companies/bomar/
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 137 times
Postby KyleR » September 1st, 2025, 10:00 am
:popcorn:
MV Verity
2002 Carver 396
Been thanked: 1310 times
Postby bud37 » September 1st, 2025, 1:30 pm
Victorboat wrote:Source of the post Hello folks,
Thank you,
Victorboat
Perhaps try other boat builders. I believe these types of parts may not be brand specific. The window/frame makers probably sold to any number of boat brands. Worth a shot.
ck36
Vessel Info: 2002 Carver 450 Voyager, TAMD74P
Has thanked: 17 times
Been thanked: 4 times
Postby ck36 » September 10th, 2025, 12:16 pm
Did you have any luck finding the rubber glazing strips?
yachtlife
Vessel Info: Carver 356 Motor Yacht
Postby yachtlife » October 20th, 2025, 3:20 am
Carver used to source most of their aluminum window extrusions and seals from Taylor Made Systems (now part of Lippert Components). You can try contacting them directly or checking with Marine Glass Specialties; they often have compatible vinyl/rubber glazing for Carver and Sea Ray models.
Another option: some owners have found good replacements through Pompanette or BoaterBits — they stock various window channel inserts and glazing profiles.
Users browsing this forum: Google Adsense [Bot] and 15 guests
