A/C first run of the season
csdaman2
Topic author - Scurvy Dog
- Vessel Info: 1996 Carver 355 Aft Cabin. Twin 454 Crusader's. Vessel Documented with the name "Justified"
- Has thanked: 3 times
- Been thanked: 2 times
csdaman2
- Been thanked: 490 times
Re: A/C first run of the season
Loosen the top of the strainer just a tad until water comes out, then tighten it back down. Don't remove the top, just loosen it a bit. May take a few second to move the air out and have water cooler out.
Once you do that, turn the a.c. back on and check for flow.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
I will do the same this spring when I launch, a short run to prime the pump. You could also prime the pump by disconnecting the hose from the inlet after shutting off the valve. Pump water through the pump with the hose, reconnect to the inlet and your system should work. I did this method last summer when my seawater pump failed and I had to install a new one.
- Been thanked: 654 times
This was the oem on my carver
https://www.google.com/search?q=passpor ... Gfs8X1A2BM:
