A/C first run of the season
Topic author
csdaman2
Vessel Info: 1996 Carver 355 Aft Cabin. Twin 454 Crusader's. Vessel Documented with the name "Justified"
Has thanked: 3 times
Been thanked: 2 times
Postby csdaman2 » April 13th, 2017, 8:46 pm
tried to turn on the a/c today for the first time. the blower seemed to come on but no snoflake on the control pad. no water was pumping either. the sump breakers we're on but the a/c unit ever came on? any ideas?
csdaman2
Has thanked: 64 times
Been thanked: 481 times
Re: A/C first run of the season
Postby waybomb » April 13th, 2017, 8:53 pm
Is your seacock leading to the pump open? Is your strainer air bound?.Does the pump run?
Loosen the top of the strainer just a tad until water comes out, then tighten it back down. Don't remove the top, just loosen it a bit. May take a few second to move the air out and have water cooler out.
Once you do that, turn the a.c. back on and check for flow.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » April 13th, 2017, 9:06 pm
Did you turn on the breaker for the AC raw water pump?
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » April 13th, 2017, 10:45 pm
Why are we posting this multiple times?
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Been thanked: 601 times
Postby tomschauer » April 13th, 2017, 10:56 pm
don't forget to check the stat and be sure its in the cooling mode, and the set temp is below the room temp........With a call for cooling the compressor would come on for a short while even if it had no water flow.
Been thanked: 468 times
Postby RGrew176 » April 14th, 2017, 3:08 am
You probably need to prime the pump. Last spring when I launched my 3007 the A/C did not work. Like you no water coming from the outflow. I took the boat out for a run getting her up on plane. When I returned to the dock my A/C was working as the run on the lake forced water up into the pump.
I will do the same this spring when I launch, a short run to prime the pump. You could also prime the pump by disconnecting the hose from the inlet after shutting off the valve. Pump water through the pump with the hose, reconnect to the inlet and your system should work. I did this method last summer when my seawater pump failed and I had to install a new one.
2022 Stingray 182 SC
Been thanked: 646 times
Postby g36 » April 14th, 2017, 3:04 pm
Don't know what air conditioner you have but on some you can program for heat only,cool only, or automatic mode you may want to check the program and see if cooling is enabled. Does your panel resemble this?
This was the oem on my carver
https://www.google.com/search?q=passpor ... Gfs8X1A2BM:
Users browsing this forum: No registered users and 4 guests
