Water in forward and mid bilge
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
I need help understanding how and where this water could come from? The forward bilge has the AC thru hull fitting. The mid bilge has three thru hulls. A airmar transducer and airmar speed/temp sensor. I installed a Raymarine/flir transducer this winter. (of course this isn't the problem)
Need help once again.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Been thanked: 601 times
Re: Water in forward and mid bilge
All thru hulls, shower sump, water heater and relief valve for same, all potable water piping, a/c unit pump and piping, engine and generator strainers and piping below water line.
A quick check is to turn off all your dockside water,potable water pump and a/c. If water continues to rise....look at thru hulls and piping. A thru hull can seep at the penetration as the sealant is now close to 20yrs old if they were never removed and resealed.
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 469 times
- Been thanked: 1765 times
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
dsolo wrote:Source of the post Is there a secret to detecting a slight water flow from the pipe fitting or thru hull connection?
Dry the area you suspect is the source and put down a lot of foot powder or some talc product. If it is leaking you'll see the water spread out. Should be worth a try to find the leak.
- Been thanked: 646 times
- dsolo
454 EFI Crusaders
My galley sink drains directly out an above water thru hull. I did find the forward sump with a broken flange from the forward ac drain. I am replacing it.
Viper,
This spring I found one of the rudder stuff boxes with only a couple threads engaged. It had been leaking. I replaced all the stuffing. I checked each one. Found on of the engine shafts required tightening. The others seemed fine. Will check them again.
I plan on emptying the potable water tank and heat water tank to eliminate them.
Jcoll,
There is a lot of water in the bilge. I wish I could get to the point to implement your suggestions. I will try removing the water with the bilge pump and wet vac. Perhaps if it is a thru hull fitting it will be apparent at the low water mark?
Going to the boat tomorrow. Will update findings.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
I won't go into how I found it, but thanks to the group once more. I would have been like a dog chasing it's tail.
All suggestions on procedures to determine what failed and methods for repair. Should I leave this to the professionals?
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 78 times
- Been thanked: 1093 times
Depending on how bad it's leaking, you might also try to clean the joint from the outside with a scotchbrite pad and put some 5200 on it. Supposedly it can be applied underwater and will harden underwater, although it will take a while with the cold temps.
