Water in forward and mid bilge
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
I need help understanding how and where this water could come from? The forward bilge has the AC thru hull fitting. The mid bilge has three thru hulls. A airmar transducer and airmar speed/temp sensor. I installed a Raymarine/flir transducer this winter. (of course this isn't the problem)
Need help once again.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Re: Water in forward and mid bilge
All thru hulls, shower sump, water heater and relief valve for same, all potable water piping, a/c unit pump and piping, engine and generator strainers and piping below water line.
A quick check is to turn off all your dockside water,potable water pump and a/c. If water continues to rise....look at thru hulls and piping. A thru hull can seep at the penetration as the sealant is now close to 20yrs old if they were never removed and resealed.
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
dsolo wrote:Source of the post Is there a secret to detecting a slight water flow from the pipe fitting or thru hull connection?
Dry the area you suspect is the source and put down a lot of foot powder or some talc product. If it is leaking you'll see the water spread out. Should be worth a try to find the leak.
- Been thanked: 654 times
- dsolo
454 EFI Crusaders
My galley sink drains directly out an above water thru hull. I did find the forward sump with a broken flange from the forward ac drain. I am replacing it.
Viper,
This spring I found one of the rudder stuff boxes with only a couple threads engaged. It had been leaking. I replaced all the stuffing. I checked each one. Found on of the engine shafts required tightening. The others seemed fine. Will check them again.
I plan on emptying the potable water tank and heat water tank to eliminate them.
Jcoll,
There is a lot of water in the bilge. I wish I could get to the point to implement your suggestions. I will try removing the water with the bilge pump and wet vac. Perhaps if it is a thru hull fitting it will be apparent at the low water mark?
Going to the boat tomorrow. Will update findings.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
I won't go into how I found it, but thanks to the group once more. I would have been like a dog chasing it's tail.
All suggestions on procedures to determine what failed and methods for repair. Should I leave this to the professionals?
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Depending on how bad it's leaking, you might also try to clean the joint from the outside with a scotchbrite pad and put some 5200 on it. Supposedly it can be applied underwater and will harden underwater, although it will take a while with the cold temps.
