Rebuilding Sherwood E35 raw pumps
- Been thanked: 491 times
Re: Rebuilding Sherwood E35 raw pumps
I guess if the pump seizes you'd have a mess. I wondered the same thing. However, I've NEVER heard of a pump actually seizing. Bearings go bad but they get sloppy rather than seize.
There's actually a small bracket that holds the pump from rotating, but from what I've read it's hardly necessary when you have the reinforced hoses in place. I wondered if the stiff hoses (full of water) also could sideload the pump and cause issues, but I guess installs deal with that.
I measured the old cam vs the new cam. The old ones (which have about 1200 moderate-use hours) were about 0.19" at the thickest part. The new one was about 0.24". The new one was a lot longer than the old one... I don't know if that is from wear, or from a slightly different design.
Here is what they both look like:
I did not do the whole seal and bearing kit. I'll do that over the winter. I'm curious what difference this will make. I should know tomorrow.
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
MakinTime wrote:Source of the post I am just seeing this post now KM how many hours are on pumps? Did it make a difference in steam?
My engines have about 1200 hrs, but pretty light to moderate duty. I don't often cruise over 20 mph, although the boat will do 28.
I did not do the whole pump rebuild yet. I have not really noticed much steam except when it's cool outside and then it's hard to tell if it's normal or not. Haven't had a problem with heat either but I always wondered how long the cams would really last and how much they would be worn. Now I know. I'm probably going to do the complete rebuilds on both pumps before launch this year. If I bring them home to do it, I might try to rig up a "before" and "after" flow test too.
- MakinTime
- mjk1040
- Been thanked: 248 times
- mjk1040
Users browsing this forum: Google Adsense [Bot] and 23 guests
