Port Engine Overheating
Re: Port Engine Overheating
I hate to be the bearer of bad news, but the impellers have a VERY short life without flow.
Hopefully they are still ok.
- mjk1040
- Been thanked: 248 times
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
- RickieT
- Contact:
- RickieT
- Contact:
Many thanks
Rick
- Has thanked: 602 times
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
After some thought, I figured the pressured coolant was going out the exhaust when the engine was warm and running.
When the engine was off, the coolant went past the riser block-off plate and seeped into a couple cylinders.
I removed the plugs, taped a Q-tip to a chop stick and stuck it into each cylinder until I found the coolant.
If its older then 6 yr old, replace your exhaust system....
If the like button worked, I would press it twice.
- RickieT
- Contact:
