Port Engine Overheating
Been thanked: 601 times
Re: Port Engine Overheating
Postby tomschauer » February 16th, 2018, 9:12 pm
As Mike mentioned you did have some flow previously. When you say your first attempt failed miserably, how long did you leave the engine run with no flow?
I hate to be the bearer of bad news, but the impellers have a VERY short life without flow.
Hopefully they are still ok.
Been thanked: 246 times
Postby mjk1040 » February 17th, 2018, 4:36 am
Rickie; When the mechanic changed the impellers did u see the old port side impeller? Was it all in tack? Ask the mechanic, which I doubt, if he back flushed the system before putting the new impeller in. If the old impeller fell apart it could be plugging up the first path of the raw water flow at the cooler. Then again if the first path, cooler, is plugged up u may have to remove it and put it in the descaler bucket or replace it. You are going to have to start checking the entire flow pattern of the system looking for blockage.
RickieT
Vessel Info: Carver 350 Mariner 1997
Has thanked: 18 times
Been thanked: 3 times
Postby RickieT » February 25th, 2018, 4:13 pm
I will dot that....many thanks
RickieT
Postby RickieT » March 9th, 2018, 4:04 pm
I'm going to go back in and check the impeller again...I bet anything there's a piece of impeller in there. It's still overheating but not as bad after I flushed the heat exchanger.
RickieT
Postby RickieT » March 15th, 2018, 4:35 pm
Food for thought...took the boat out again and at about 3000 the temp started rising. When I throttled down the temp went back down so definitely better then previous rides...but still running hot. I did notice that the coolant overflow bottle was full when we left and almost empty when we docked. Anything I need to troubleshoot or look for in that department. I did purchase an infrared thermometer, by the way. Still need to check impeller but maybe it's a coolant issue? What am I looking for on that end?
Many thanks
Rick
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » March 15th, 2018, 8:27 pm
Well Rick, if it were me , I would remove the heat exchanger from the boat , take to a rad shop and have it boiled ,inspected for cracks etc and pressure tested so once and for all you will be able to check that off the list ......because if it is not that and your coolant is going away then we are talking at the least some engine inspection......your issue sounds just like when your car rad is worn out......good luck man......... :beergood:
Postby tomschauer » March 15th, 2018, 11:01 pm
Rick, I believe I would seriously consider manifold and riser replacement. This would be the most likely place for both of these problems to originate. Overheating due to scale build up and coolant loss due to internal corrosion.
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Postby SanJuanDreamer » March 15th, 2018, 11:14 pm
When I had coolant go missing, I rented a radiator pressure pump and noted it lost pressure, but there was no coolant anywhere to be found but it was going somewhere.
After some thought, I figured the pressured coolant was going out the exhaust when the engine was warm and running.
When the engine was off, the coolant went past the riser block-off plate and seeped into a couple cylinders.
I removed the plugs, taped a Q-tip to a chop stick and stuck it into each cylinder until I found the coolant.
If its older then 6 yr old, replace your exhaust system....
Postby tomschauer » March 15th, 2018, 11:32 pm
I like the Q tip and chop stick trick!! Great idea.
If the like button worked, I would press it twice. :-D
RickieT
Postby RickieT » March 30th, 2018, 5:56 pm
Update: Brought the heat exchanger to a radiator shop and had it pressure tested and flushed out. Mechanic said it was about 30-40% clogged and all clear now. Going to put it back in and check the hoses and see if the engine overheats when I take it out on Thursday my day off...fingers crossed. I did look over maintenance records and the recently had new risers installed. Hoping that is true...
