Looking for Onan model number
dmunneke
Vessel Info: 1985 3697
Has thanked: 3 times
Postby dmunneke » June 27th, 2019, 12:23 pm
I have a 1984 3697... Any idea what the onan model it has in it.. Its a 6.5 model...?
Re: Looking for Onan model number
Postby g36 » June 27th, 2019, 2:07 pm
Good chance it's a MCCK can you find the serial
number? I had one of these in my f32 trojan what's going with it?
BenTen
Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
Has thanked: 20 times
Been thanked: 32 times
Postby BenTen » June 27th, 2019, 4:37 pm
g36 wrote:Source of the post Good chance it's a MCCK can you find the serial
Unless it was replaced it is indeed an Onan MCCK 6.5. I have an 84 3697 as well with this genset, let me know if you have any questions- I'll do my best to help!
Thanks,
Ben in SC
dmunneke
Postby dmunneke » August 7th, 2019, 4:17 pm
Thanks Guys... Somebody was messing with it and I think stole one of the heat sensors.. Nice... I'm guessing not easy parts to find.
Postby Viper » August 8th, 2019, 10:32 am
dmunneke wrote:Source of the post Thanks Guys... Somebody was messing with it and I think stole one of the heat sensors.. Nice... I'm guessing not easy parts to find.
If it's an MCCK, parts are out there but typically pricey. Some parts are obsolete on earlier specs but likely available on-line The MCCK units are pretty much all the same with some minor engine component differences over the years, and control and generator assembly changes. You'll need to know the spec; A, B, C, etc. to ensure you get the right parts.
Why do you "think" a sensor is missing and what is the unit doing/not doing? Is it running?
dmunneke
Postby dmunneke » August 8th, 2019, 2:54 pm
I think its missing because its not on the exhaust elbow and the wire is there without the sensor attached to it.. :-P
No the think part is why its missing.. I didnt take it off !
Postby Viper » August 8th, 2019, 7:14 pm
Have you tried running it? I believe the switch is NC (normally closed) so jumping the two wires will complete the ignition circuit. You shouldn't use the unit without the switch but this will allow you to see if it actually runs if you've never had it running before.
dmunneke
Postby dmunneke » August 15th, 2019, 9:10 am
Yeah thats exactly the plan.. It has run perfectly but I haven't had it running for a couple years now.. Its going to require some tinkering.. I havent tried to fire it yet since I noticed the missing part
