Viper wrote:Source of the post I was getting concerned because that unit is not rated for installation in a gasoline engine bay. Technically, neither is the fuse in the picture.
Do you suggest I move that fuse inside?
vineyardgray wrote:Source of the postViper wrote:Source of the post I was getting concerned because that unit is not rated for installation in a gasoline engine bay. Technically, neither is the fuse in the picture.
Viper wrote:Source of the post If the installation requires doubling up your wiring on each side, you must also do the same at the batteries for connecting them in series. The effective wire size must be used throughout the entire circuit which includes the wiring connecting the batteries to each other. In your case, solid bars are used for some of the battery connections, they also need to be rated for inverter load at full output.
You should also use terminal covers on the posts of the switch and fuse block. I believe those blocks have custom covers available.
I mentioned that the fuse in the picture is not specifically stated to be ignition proof for gas engine bays. You should ask the electrician about that. It may be recommended in the installation manual but they are likely assuming you're installing it outside of the engine compartment since the inverter isn't rated to be there. It would be fine if it were a diesel application. Unless something has changed, I believe the only high amperage fuse for inverter installations that is specifically stated to be ignition proof is the ANL type.
Users browsing this forum: Google Adsense [Bot] and 12 guests
