What vaculush Vcuum oump do I have?
Barnaclebill
Vessel Info: Lindy Star
2004 Carver 360 Mariner
Volvo 5.7 Liter GXI Gas Engines
Postby Barnaclebill » September 19th, 2020, 4:12 pm
I have a 2004 Mariner 360. My Vacuflush vacuum pump needs a rebuild. The toilet is a 706 with a separate vacuum pump. It has a white cover guard held on by two screws. I can't find an exact image or a part number on the pump. Anybody have any ideas?
BarnacleBill
Barnacle Bill
Lindy Star
Twin Volvo 5.7L GXII-F
Southport, NC
Been thanked: 601 times
Re: What vaculush Vcuum oump do I have?
Postby tomschauer » September 20th, 2020, 12:42 pm
It is a Sealand either an S or T pump. If it runs, you most likely just need the duck bill valves. Both pumps use the same duckbills.
Barnaclebill
Postby Barnaclebill » October 1st, 2020, 10:49 pm
Thanks for the info.
Barnacle Bill
Lindy Star
Southport, NC
JohnS
Vessel Info: 2003 350 Mariner
Has thanked: 39 times
Been thanked: 16 times
Postby JohnS » February 7th, 2021, 6:41 am
Been thanked: 1180 times
Postby Midnightsun » February 7th, 2021, 7:12 am
Barnaclebill wrote:Source of the post I have a 2004 Mariner 360. My Vacuflush vacuum pump needs a rebuild. The toilet is a 706 with a separate vacuum pump. It has a white cover guard held on by two screws. I can't find an exact image or a part number on the pump. Anybody have any ideas?
BarnacleBill
What exactly is your problem? For sure the duck bills need replacing as mentioned. Mine lasted 10 years before I started having issues and now will changed them every 8 as a preventative maintenance routine. 4 duckbills and a new bowl seal should do the job. I did change the bellows on one but think that was overkill. Do have a set of duckbills and bellows on board just in case. ;-) Much better to do this when you have time as opposed emergency repair in the middle of vacation.
Postby Midnightsun » February 7th, 2021, 7:56 am
By the way, bowl seal kit is available in the US via USPS here for a ridiculously low price. https://www.aliexpress.com/item/4000132 ... 0132846914
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 406 times
Postby Cooler » February 8th, 2021, 12:34 pm
You may be able to just replace the accordian bellows at the top of the pump. Open the top, see if the bellows are wet or gunked up. That is a frequent fail for those pumps. Replace the duck bills at the same time. 8-) er
Cooler By The Lake
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » February 8th, 2021, 7:06 pm
Need to know what's happening first or not happening. Don't start throwing parts at it until you diagnose it properly as some components can be pricey.
- does the pump run?
- does the pump eventually shut off?
- how long does it run for before shutting off?
- does it cycle on it's own periodically?
- will water remain in the bowl if you don't flush?
- if the pump is working and shutting off after it builds a vacuum, do the contents of the bowl evacuate when you push the pedal?
- when were the duckbill valves last inspected/replaced?
- why are you rebuilding the pump?
etc....
Been thanked: 646 times
Postby g36 » February 9th, 2021, 7:37 am
the biggest problem with these is usually being able to get to them often buried in some space you can hardly get too.
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
Postby rjr » February 24th, 2021, 10:02 pm
Viper: I was getting ready to post a question about duckbills until I saw your list of questions. So here are my answers:
Yes, the pumps run. (2 heads).
Yes, pumps shut off.
Pumps run 30 to 40 seconds before shut off - could be a little less.
Hardly ever cycle on their own.
Yes, water will remain.
Yes, full evacuation.
Duckbills were replaced approximately 5 years ago.
Duckbills on Admiral's head are making a "weet weet weet" noise just before shutoff. So I figured it was time to replace. Then I figured might as well do both.
Question: Do you know where vacuum generator for forward head is located? Are generators located next to each other on starboard side of engine room near aft head holding tank? I have a waste & water schematic - if anybody wants one shoot me a PM with your email.
